メインコンテンツにスキップ
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
46回答 すべてを表示
Why is my OP-1 not turning on?
I have been storing my OP-1 and using it since 2013. The other week it stopped turning on; currently, when I flip the power switch, I hear the power get to the speaker but the screen does not glow at all. Is this a screen issue, ui issue, or is it something else? It has turned on previously but it only works after I perform a firmware update or sparingly at any other time.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント
Hello @amccaw1590 , Have you found a fix?
Mine stopped working yesterday night. I thought it was because the battery was empty but when I connected it to my laptop nothing happened.
I hear the power get to the speaker but same, the screen remains black.
I didn't upgrade the firmware. Just use it and then it stopped working :(
I tried to reset the factory settings but didn't work.
Any idea how to fix it?
さんによる
Were you able to fix this?
さんによる
Hey, has anyone been able to resolve this issue or find a place to diagnose and repair the problem?
さんによる
コメントを追加
2件の回答
最も参考になった回答
I’ve had this problem as well. I was able to fix using the instructions here:
https://www.reddit.com/r/OP1users/commen...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It has happened a couple times to me and has required a firmware update both times
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How did you update the fw if it doesnt turn on?
さんによる
コメントを追加
回答を追加する
Angelo McCaw さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 19
過去 30 日: 47
今までの合計 2,325
