メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年11月4日発売。モデル番号A1865、A1901。GSMまたはCDMA対応モデルがあり、容量は64GBまたは256GB、カラーはシルバーまたはスペースグレイ。読み方は「iPhone 10」と同じです。
iPhone X Won't turn on
iPhone x was half way charged last night. Put it on to charge. When I got up this morning it is black screened and will not power on. I have Tried the volume up down and then holding power on still nothing. iTunes won't even recognize it. I've tried diffferent charging cables and blocks nothing will get it back on. Any suggestions, besides taking it to apple? I plan to do that if I don't get it back on
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 32
2 件のコメント
My iPhone X sim port was open and it feel inside the water and turn blank on the screen what can I do to solve this
さんによる
In addition to a hard reset, the solution to this problem is to use the factory reset. Only in the process of using the factory settings, the data on the iPhone will be deleted. Of course, if you can contact the Apple store, this is the best. Otherwise, you can also use the Fonecope iOS System Recovery tool. https://www.fonecope.com/iphone-wont-tur...
さんによる
コメントを追加
9件の回答
ベストアンサー
Well, since this is a DIY forum, if you want to try troubleshooting it yourself, see the wiki iPhone X Won’t Turn On.
Honestly I know that you don't want to bring it to apple, but if this turns into a more serious issue it will cost you a lot of money. I say you should get it replaced/fixed by apple before your warranty is up. (assuming this is a new device you bought recently)
このアンサーは役に立ちましたか?
スコア 5
12 件のコメント:
That's what I did . Thanks
さんによる
Okey! make sure to hit accept as solution!
さんによる
Hi! This happen to my iPhone XR is it hardware problem? If yes what did they do to your phone. Pls response, so frustated right now.
さんによる
Hi is your XR still good? Im planning to get a XR, because my IPhone X won't turn on and they told me that it's because of its logic board. They said I need to replace the phone because they can't fix a logic board issue.
さんによる
I have an IPhone x with the same problem, wont turn on or take charge, Itunes wont recognise it, the local official repair shop tells me that they will replace it with a new IPhone against a fee, my warranty just expired. Please put a solution.
さんによる
7件以上のコメントを表示
コメントを追加
最も参考になった回答
Hi! This just happened to me and I talked to an advisor on Apple’s website! He gave me 3 easy steps to try and it worked for me so hopefully it’ll work for anyone else too! PSA: This only works with the iPhone X
  1. Press the “up” volume button and quickly release
  2. Press the “down” volume button and quickly release
  3. Hold in the lock button on the right side of the phone for about 5 seconds (or until the apple logo appears)
Thats it! Hope this helps someone :)
このアンサーは役に立ちましたか?
スコア 54
34 件のコメント:
I couldn’t believe this worked. I thought for sure I was going to have to send in my phone. Thanks for sharing!
さんによる
OMG! thanks! such a mystery as to why the sidways button stopped powering on the phone, but this did the trick!
さんによる
marry me andrea, it worked with me, i was super terrified because the warranty of my iphone X has expired 10 days back only. This was a moment for me only because of you, the apple adviser told me to press the volume down key along with the power button, which was not working, what a jerk he must be, thanks babe!
さんによる
That was great thanks for the tip worked like a charm
さんによる
Thank you! Saved me the time and headache of trying to get it fixed/replaced!
さんによる
29件以上のコメントを表示
コメントを追加
1.Force Restart or Reboot your iPhone
2.Charge Your iPhone Correctly, Check if the charging wire is broken or loose.
IF iPhone  Gets Stuck During Startup and Screen is Black.Connect your device to a computer then launch iTunes. After your device is connected perform force restart.
Sometimes the changing problem may arise that will only allow the charge from some particular charger or maybe it only support the charge while connected to the PC, not to the wall charger.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
The iPhone XR was completely blank. It was on a charger for 2 days. When I connected to I tunes on a pc, I couldn’t get to any programs except music. When I closed out music the xphone lit up, but it only had 3% charge. It was on chargers that I used before and it charged, but I assumed that it wasn’t able to charge. This phone is only 3 months old. I’ve noticed it loses charge very fast during the day. I’m not sure if the battery isn’t defected. I will turn off programs to a bear miminum to see if this makes a difference...
さんによる
How did you switch it on then? Did it switch on?
さんによる
Worked when connected to computer while itunes was launched, thanks for that tip.
Didn't work with charger that worked with another iphone X.
Didn't work with force restart or reboot.
さんによる
コメントを追加
there are a couple steps, but it is likely an apple warranty claim.
however, try leaving it plugged in for 24 hours in a high amperage, (2A or more) charger. the battery may just need a kick.
Anything further would involve opening the device, which would void the warranty.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thanks. I already Did this too .. Thanks for the input Took it to apple and they replaced it. Apparently its a known issue. No way was I opening even with my 7 years experience of working on phone lol. Especially with the Trap on the Face ID. So they gave me a new one. and Made sure it was a Brand new one lol
さんによる
Using a 2A charger is what does the trick for me.
さんによる
コメントを追加
Here’s the guide on how to fix my iPhone X won’t turn on Fix Start Up screen with the black screen and Blinking While apple logo on the black screen: https://www.howtoisolve.com/my-iphone-x-...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This Also happen to my IPhone X, The reboot/restart was not working for me at all ! My phone was on the charger & took my SIM card out it turned on. However make sure it’s not on the lock screen must be unlocked and move it around so it doesn’t shut off again! Hope this helps
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hello my iphone is not working. All i get is the Apple logo when it is on the charger that appears and disappears every 15-20 seconds. I have tried the Up Down Side Power button thing, unfortunately to no success. Itunes won’t recognise the iphone X either. Does this mean a new phone? I bought my iphone through a telco NOT apple, so hope they might give me a new phone if the problem cannot be solved
  • Digital_Archivist
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
If it is less then a year old even if you bought it through a Phone Company Apple will replaced under warranty, But it sounds like it may need a new battery or another part. If your in the year warranty Take it to any apple store and you should be fine. If not then I would take it there or any place to have them diagnose it. It could be anything from the Battery to a Bad cable that causes the phone to Boot loop like you described.
さんによる
It’s garbage piece it $@$* company same happened with me , never buy their products again
さんによる
コメントを追加
My iPhone xr won't let me click on apps and when I try turning it off the power off screen won't show
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Little trick for ya if you end up having to do hardware. I have experienced this many times. If it is actual hardware. It is the charge port. Before you fully replace charge port attempt this. Works about 50% of the time. Without full disassemble. Attach the new charge port, disconnect and reconnect the old one. Not sure why this works but it does.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
service さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 45
過去 30 日: 328
今までの合計 325,203
