How To Reset Belkin Wireless Router To Factory Settings?
My belkin wireless router is not working properly. I want to reset my router password can any one guide me in easy way ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here is the link
If you cannot open it. Look at the back, near the ports, for a reset button. Hold button for 15 secs. Then wait for a minute.
Other Methods
Go to terminal (Window key + r) and type ipconfig to pull up your IP Address OR type ip address on your browser (google i.e.) and it will show your ip. Type that in a browser and it should grant you access to your router unless you locked it. You can go into the settings and run factory Reset.
Manual reset is a easier.
Good Luck
このアンサーは役に立ちましたか?
You should also go belkin's website and see if there is an updated firmware and install it if available.
^fact.
If it does give you a difficult time doing the update, you should be able to download it off their website and manual update it by access the router via browser.
lets Put in this Way - When You reset belkin router You Reset all Privious settings and its no rocket science.
Let me Walk You Through this -
Plug the belkin router to the power And turn it on
Use a Paperclip and push the reset key and hold it for 20 secounds Till all lights start Blinking
Reboot the router . For any other step Or Setup Guide visit to source Reset belkin router
see it helps you solve the Problem with your belkin wireless router
このアンサーは役に立ちましたか?
There is two way to reset
1. Hard reset
2. Soft reset
Hard Reset:-
Soft Reset:-
* For this you need to check that is your computer is connected with network or not.
* Once you logged in.
このアンサーは役に立ちましたか?
How to reset the router?
Once the reset done, then do the following things for setup Belkin router
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 21
過去 30 日: 69
今までの合計 6,899
1件のコメント
Hey there, that’s a great question. There are actually many ways to Reset Belkin Wireless Router to Factory Settings. I found a video on YouTube that explains a few simple ways on how to Reset Belkin Wireless Router to Factory Settings.
I’ve tried many different ways to do this. Here’s a link to a video that gives some great tips.
https://dausel.co/EI26JJ
click on that link above and once you land on the page, click where it says “I am not a robot” and then you will be redirected to the YouTube video that shows how to reset BELKIN - Reset Factory Defaults Belkin Wireless Router.
raymond さんによる
