メインコンテンツにスキップ
Repair guides and support for wired or wireless devices that provide internet connectivity.
How To Reset Belkin Wireless Router To Factory Settings?
My belkin wireless router is not working properly. I want to reset my router password can any one guide me in easy way ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Hey there, that’s a great question. There are actually many ways to Reset Belkin Wireless Router to Factory Settings. I found a video on YouTube that explains a few simple ways on how to Reset Belkin Wireless Router to Factory Settings.
I’ve tried many different ways to do this. Here’s a link to a video that gives some great tips.
https://dausel.co/EI26JJ
click on that link above and once you land on the page, click where it says “I am not a robot” and then you will be redirected to the YouTube video that shows how to reset BELKIN - Reset Factory Defaults Belkin Wireless Router.
さんによる
コメントを追加
4件の回答
ベストアンサー
Here is the link
If you cannot open it. Look at the back, near the ports, for a reset button. Hold button for 15 secs. Then wait for a minute.
Other Methods
Go to terminal (Window key + r) and type ipconfig to pull up your IP Address OR type ip address on your browser (google i.e.) and it will show your ip. Type that in a browser and it should grant you access to your router unless you locked it. You can go into the settings and run factory Reset.
Manual reset is a easier.
Good Luck
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
You should also go belkin's website and see if there is an updated firmware and install it if available.
さんによる
^fact.
If it does give you a difficult time doing the update, you should be able to download it off their website and manual update it by access the router via browser.
さんによる
コメントを追加
最も参考になった回答
lets Put in this Way - When You reset belkin router You Reset all Privious settings and its no rocket science.
Let me Walk You Through this -
Plug the belkin router to the power And turn it on
Use a Paperclip and push the reset key and hold it for 20 secounds Till all lights start Blinking
Reboot the router . For any other step Or Setup Guide visit to source Reset belkin router
see it helps you solve the Problem with your belkin wireless router
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
There is two way to reset
1. Hard reset
2. Soft reset
Hard Reset:-
  • Find a reset button on the device.
  • Generally hidden back of the router.
  • Use Paperclip to press the button.
  • Press it for approx 10 to 15 second.
  • Release the button and restart it.
  • Now your router is ready to connect.
Soft Reset:-
* For this you need to check that is your computer is connected with network or not.
  • Once connected. Open a web browser and type your router IP address.
  • For belkin it is 192.168.2.1
  • This will open a belkin setup page.
  • Use the username and password.
* Once you logged in.
  • you found a option with labele Reset Router.
  • Select it and router will have cycled or under go in the process of resetting.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
How to reset the router?
  1. Open the browser on your computer.
  2. Type the default IP address ‘192.168.2.1’ and press ‘enter’. You will be directed to a web page.
  3. Click ‘login’ on the upper right corner of the page.
  4. Enter the username and password, and submit.
  5. Click on the Utilities section and click restore factory defaults.
  6. On ‘click restore factory defaults’ option, you have to ‘select restore defaults’ option.
Once the reset done, then do the following things for setup Belkin router
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
verma.kirti さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 52
今までの合計 7,726
