メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone6- Black Screen Display
Dropped my phone a few feet up, and since then half of my screen display is just black, making it near impossible to use my phone.
I have tried the hard reset but nothing has changed. The phone was bought directly from Apple, and hasn't had many other problems.
Thanks for reading, I would really appreciate some help fixing my phone.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
This response is late but hopefully it can help others.
There are two possible causes here. One is a damaged screen assembly. This can be easily replaced by ordering this part and following this guide.
The other possibility is that the backlight circuit was damaged and needs to be repaired. This requires a micro-soldering repair and is not DIY .
iPhone 6 Screenの画像
製品
iPhone 6 Screen
$44.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
To fix iPhone black screen of death, you can also restore your iPhone through iTunes. However, please make sure you have backed up all your important data from your iPhone via iTunes to restore iPhone with the iTunes backup. And during the process, iTunes will erase all data and settings on your iPhone to fix your iPhone. Now, you can start to fix your iPhone black screen issue.
> Firstly, get a USB cord to link your iPhone to computer and launch iTunes on computer.
> Secondly, click the iPhone icon on iTunes, then hit the Restore iPhone option on the right panel on iTunes window.
> Finally, confirm your action to restore your iPhone on the pop-up window. Then iTunes will start to erase all data and settings on your iPhone, download and install the latest iOS version on your iPhone. Finishing the process, your iPhone black screen issue will be fixed.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
この回答は他の質問に帰属しています。
your only option is to replace the whole screen!hope that helps or check the led wires
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
この回答は他の質問に帰属しています。
You could ask for help from a professional iOS rescue tool - iOS System Recovery to fix your iPhone error. This tool specializes in fixing all types of system problems on iPhone. You can easily operate the program and quickly fix different problems like stuck on Apple logo, iPhone error 9006/53/56, iPhone stuck on recovery mode, iPhone blue/black/white/red screen of death and so on.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
K.Coleman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,909
