メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Acer Aspire 5552の修理ガイド、ユーザーマニュアル、技術仕様。Acer Aspire 5552は、15.6インチの画面、250GBのストレージ、DVD書き込みドライブを搭載した低価格ノートパソコンです。手頃な価格ながら、標準的な性能を備えています。
It won't power up.
I purchased a used Acer aspire 5552 without a charger. Purchased replacement charger. Plugged it in turned it on, have to reset Windows. I turned it off so I could reboot and now when I hit the power button the blue light on the power button comes on, I hear the laptop start (fans and drives) then it just shuts down. I was hoping after a good charge it would start but it still wont. So I looked and you guys say if it charges and won't start probably a battery, but it still won't turn on even when plugged into the power adapter. So help please!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
The battery seems to have a problem. Try changing to another battery or If your warranty is still active try using it.
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Try removing the power adapter and the battery and holding the power button for 10 seconds. Wait 30 seconds and then put the battery back in and see if it boots. Some HP laptops use this procedure as a hard reboot. If this doesn't work, try re-seating the RAM in your laptop.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Anthony Kouttron's suggestion usually works in cases like this. You might try leaving it plugged in overnight if it doesn't work immediately after trying it.
さんによる 共有
I have an old Acer Aspire 5630 with all my email on it. A few days ago it stopped starting, when I pushed the power button it "started" 1 second and then stopped. Because the battery is as old as the laptop the power supply is always on.
So I followed Anthony's procedure and it worked!! Thanks a lot!
さんによる 共有
コメントを追加
回答を追加する
Stacy Prenot さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 30
今までの合計 1,843
