メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
333MHzプロセッサ付き、4.3インチワイドスクリーンLCDディスプレイを搭載しています。モデル番号はPSP98510です。このデバイスを修理する際には、一般のドライバーとこじ開け用ツールが必要です。
It doesn't turn on
Hi, everything started when backlight just stopped working. Like your turn it on one times it works but other time after a few minutes it just stopped working. And then even it doesn't turn on anymore. Like if you're charging orange comes on but fades off after a few minutes and PSP won't turn on anyways. Please help :(
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi!
Let's try this: press and hold the following combinations of keys: Triangle + Square + Start + Select. While holding the buttons, flip the Power button in order to switch the device on. Release all keys as soon as the Sony logo appears on the screen (if it does).
If not, try powering it up while the charger is plugged in, but not the battery.
There is not much I can do about the backlight other than suggesting that you replace the screen.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
Oh, the problem is that Start button isn't working so I can't try that combination. I tried it turning it on without battery in it, it didn't help.
さんによる
Alright so what else is not working? How do you even pause a game if the Home bar isn't working right?
さんによる
For now I suggest that you take your console apart, reconnect the LCD ribbon cable and the Home bar cable and see if anything changes.
Also, is the front case seated properly? or are there gaps between it and the chasis?
さんによる
The thing is, the button is just broken from inside. I don't know how to explain it in English. I'll try to reconnect LCD ribbon, yes front case is seated properly.
さんによる
You could just add a picture of the damage of the Home bar
さんによる
コメントを追加
回答を追加する
Tomasz Videos さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 1,154
