メインコンテンツにスキップ
2011年10月24日発売 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405回答 すべてを表示
Mac wont start up, both fans spin for 2 secs, Sleep LED blinks once
last 4 of serial # DV7L
When trying to power up with power button :
- Mac starts
- Both fans spin for 2 sec
- Sleep LED blinks once
- all shuts off, cycle repeats without pushing power button on
Battery indicator full. When I unplug battery with adapter attached, Mac wont react at all.
Tried different RAMs, HDDs, SSDs. Reseting SMC, NVRAM, 20sec battery unplug - no luck.
Any of you guys had smth similar with POST ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Does the logic board show any signs of liquid damage?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Disconnect the mag-safe, disconnect the battery. Press and hold the power button for 10 seconds. Reconnect battery, reconnect mag-safe and tell us if it booted.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Tried it, disconnected Magsafe and battery, pwr button hold for 10sec. Reconnected Magsafe - fans spin instantly without pushing pwr button on. Pushing power button on, doesn't change anything.
No liquid damage visible.
さんによる
It should have restarted spontaneously after doing that. Your repeated procedure is NOT the sequence I told you (what about the battery)?
さんによる
tried it now, exactly as you suggested - no changes
さんによる
I am at a loss on this one. I have never seen one that wouldn't boot with this method that didn't have liquid damage. Sorry, maybe @danj has an idea.
さんによる
コメントを追加
回答を追加する
Hubert H. さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 82
