Oil inside the coil
What those it mean when there’s oil inside the coil
Usually most of the leaks on the outside of the block or inside the cylinder combustion chambers are the result of a faulty valve cover gasket. When this happens, all you need to do is just replace the valve cover gasket. Installation of a new component is rather a straight forward process. To get the job done, follow the process:
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 98
