3,5 mm jack repair
Hello. Is it possible to replace 3,5 mm jack on xperia x1? because one of pins is broken
I make an assumption that you are referring to the audio jack. From what i can see the jack is soldered to the logic board. So you will have to A) know how to solder and B) find an audio jack that is comparable to your phone. I was unable to find an original, but it looks like it is a pretty generic looking one. You could try to use one of these Mouser.com and of course follow mayer's link to get to the teardown to assist you with your phone repair. Hope that helps and good luck to you.
このアンサーは役に立ちましたか?
Hello
I have the same problem here, I need to find a spare part but I hadn't any luck. Could you please provide me a model to search for on that site or ebay? It seems that I won't find that exact design but I guess that it doesn't matter, all that matters is the number of solder pins (5) and their order. Please someone who knows electronics help this situation. There's no info on the internet about this piece of soccket.
このアンサーは役に立ちましたか?
Ashan, it would be so much better if you post your own question. I almost missed this one and I am sure many others do too. Look on the right hand site of this page you will see a link that says "Ask a question" click on it and give as much information as you can. As for your jack, it would really help to post some pictures of exactly what you are looking for. Good Luck
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,307
Please take a look at the teardown and tell us exactly which jack your talking about: Sony Ericsson XPERIA X1 Teardown
mayer さんによる
