メインコンテンツにスキップ
2011年後期モデル番号A1278 / 2.4 GHz i5 or 2.8 GHz i7 プロセッサー
20回答 すべてを表示
System failures no WIFI detected.
Hi All,
I've recently had a Mactastrophy . I've a 2.7GHz i7 late 2011, 16GB RAM and two 1TB SSD. Its a great machine worked well always. New battery from Apple 2014. A month ago it just went black screen, couldn't reboot power button wouldn't work. Then after a few hours of fidling it just started up. When I moved it it would go dead, black screen again. I suspected a loose connection so I re-seated all the cables I could. It worked well but when I'd move it with the screen open it would go black. Pressure on the bottom plate seemed to cause the fault. I when to genius bar, no support for 2011. He suggested flex cables. I changed the SSD flex cable rebooted but now no WIFI installed. I've chased this problem for 3 weeks. Changed the airport card, the wifi flex cable. Bluetooth is working. I opted for wifi dongle and upgraded to High Sierra.
But I've noticed slow refreshes on the screen and the machine doesn't operate as before. I suspect logic board.
I was wondering if its worth replacing. The net says reliable logic boards for these machines cannot be found anymore. Also my model is late enough to accept 16GB Ram, a replacement for 2011 may not.
Is it worth fixing? Does it sound like a logic board? Anything else I can try? Can good logic boards be sourced? New Macs are so expensive...any helo will be greatly appreciated. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Is there any button or switch to turn your wifi on and off.. and try installing the wifi drivers again from your laptops driver website..
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, the WiFi internal Card has no physical shutoff and the drivers have all been updated. The dongle drivers are the most up to date, but all good suggestions.
さんによる
コメントを追加
回答を追加する
Jason さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 63
