メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lenovo G500。ビジネスノートパソコンでありながら、日常使いにも適した手頃なモデルです。!
Doesn't work after BIOS update.
Hello guys I've got a problem with my lenovo G 500.I have updated the bios with tool from Lenovo.com but after that computer does not start up. if I press the power button nothing happens, but if I press the FN key with R or B key the fan starts to spin but that's all, I have tried to make a recovery flash drive with that .bin file from original Lenovo .exe file (bios update tool), but I wasnt successful, the tool (called CRISIS) doesn't work for me, I get the message "select file, but i cannot select it". So I tried to copy the file .bin to the flash drive but nothing happens. Even renaming the file to correct name doesn't help. Is it possible to recover the bios or do I need to replace the bios chip?
thank you and have a nice day
Update (11/26/2017)
I have also tried to copy the VIWGPX64.FD file on to the flash drive, laptop runs with fan to max speed, then shuts off, but no effect.
Update (12/4/2017)
I have received the BIOS chip for Lenovo G500 today. I have changed the chip sucessfully, but nothing changed. Laptop can't be powered on normally, only with FN key + B key pressed. Same thing was happening before BIOS chip change. I haven't done anything more with laptop, before I will hear some advice from you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
This is why I never update my BIOS. I trust nothing on the internet enough to let it alter my BIOS. But good luck on this.
さんによる
Yeah, it's pain in the a*s, I wanted to update BIOS, my headphone jack wasn't wokring and I wanted updated software since the computer was ready to re-assemble into new chassis. What a pity, now board is probably gone. I sent a message to BIOS chip seller, so I will see what will they suggest. Thanks for comment.
さんによる
maybe @tcrs_circuit could help out with this!
さんによる
I honestly have no clue about this. Every lenovo board I worked on turned into a headache.
さんによる
Seller sended new BIOS chip. But this didn't help either :(
さんによる
コメントを追加
3件の回答
最も参考になった回答
Have you added any hardware upgrades?
I had the exact same issue… after troubleshooting for a couple hours, I pulled the SO-DIMM that I installed 3 or 4 years prior, and the laptop booted immediately.
I wonder if Lenovo is blacklisting certain RAM modules…?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Are you running the laptop via power cord or on battery? If on battery, I would switch to the power cord just in case your battery is possibly out of power.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hello,
laptop can't even start normally, but I'm powering it by power cord.
さんによる
コメントを追加
Some laptop or PC have bios recovery mode.
Something like this
https://forums.lenovo.com/t5/Lenovo-U-an...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Tried, this guide is only for Phoenix BIOS, G500 has Insyde BIOS. I have already replaced pre-programmed BIOS chip, but without any change. I don't really know what happends, it seems like board is gone after BIOS update.
さんによる
If i remember there is way to check if BIOS slot have right voltage.Check that.I had similar problem on one PC
さんによる
I will take a look at it, CMOS battery is OK.
さんによる
コメントを追加
回答を追加する
Dominik Pecháč さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 3,052
