メインコンテンツにスキップ
2012年10月23日に発売されました。Core i5もしくはCore i7プロセッサ、Apple Fusion Driveを搭載しています。
20回答 すべてを表示
Can I use a 7200 rpm hdd in this device?
I want to replace my HDD but the following comment in the "discussions.apple.com" forum suggests to me that a 7200 rpm drive won't work.???----That may be so but neither the 21.5” iMac nor the mini offers a 7200 RPM drive option so its a moot point. Given that these drives are dead slow and that the likely reason Apple uses them is their low thermal load, Fusion or SSD are the only viable solution. Even if Apple offered SSDs larger than 512GB in these machines, the price for 1TB and larger SSDs is quite high so the Fusion becomes a viable solution.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
So in your mind RPM is the ticket for fast data. We'll in years past that was often the case over time newer recording methods have on the most part altered things. So its more important to scrub through the data sheets to be sure here.
The other factor is heat! High RPM drives tend to run hotter! So tight systems like the iMac 21.5" and the Mac Mini can encounter heat issues. So I don't recommend them here. Instead I would go with a SSD which runs much cooler and consumes less power.
So what to do?? I would go with a SSD for the boot drive (to gain the speed you want without the high heat) and put in larger HD drive as your data storage drive.
As an example I have a mini at home which now has 2 - 2 TB SSD's for my media server. I also took out the HD's I had installed and placed them into an external Thunderbolt OWC case. So my Mac Mini can run cooler. I'm not recommending you go this far I just want to give you some ideas on what is possible.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Daniel T. Gray さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 201
