Have no picture only purple screen
No picture only purple screen
If your Roku device finds out that the HDMI made with your TV is not supporting the copy and content protection technology, you are going to face an error called Roku HDCP error code 020. The error code is the 020 and along with the message, you are going to see that your screen might have gone purple. The main cause of the problem is if the TV or AVR does not support HDCP. there are various steps that you can follow in order to figure the main issue and eliminate it once and for all.
Follow these steps mentioned below:
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 4
過去 30 日: 32
今までの合計 2,994
How long have you had three Roku?
xDERPYx xCREEPERx さんによる
