メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Huawei Honor 8は、5.2インチ1080pディスプレイ、4GBのRAM、12MPのデュアルカメラセンサー、指紋センサー、USB Type-Cポートを搭載し、2016年に発売されたAndroidスマートフォンです。モデル:FRD-L04
Can't perform a factory reset
I have forgotten my password and as a result I am unable to reach my settings. I have not performed a back up and I have holiday photos on my phone I would like to keep. I have tried to perform a factory reset but I have been unsuccessful. What should I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right
さんによる
コメントを追加
3件の回答
ベストアンサー
@preheat If you preform a factory reset you will loose your photos the only way in is to keep trying to get your password right . If you get locked out after to may failed attempts then go here then instead of factory reset in step 4 select wipe cache partition. do that and you will get a new round of password attempts . If you made the password you will eventually get it . Hope this helps
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Tryn to rest huawei android to factory settings but im stuck on formatting/data
さんによる
It bypasses the scrolling option to wipe data
さんによる
コメントを追加
[] Turn off your Android device. ...
[] Press and hold the "power", "volume down", simultaneously. ...
[] Release the buttons once your Android device is powered on. ...
[] Scroll using your "Volume up and down" button until you find the "wipe data/factory reset" option.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
This will cause lose of holiday photos
さんによる
yeah i concur... but assuming he cant remember his password how much choice does he have? he can keep trying though until he gets the correct password. And hopefully if he has to reset the device, he has a back up for his files.
さんによる
I hope you dont mind I made a correction to your answer I removed the camera button part as this was incorrect but the rest was good
さんによる
yeah I appreciate it man,... tnx
さんによる
コメントを追加
hi, i have reset my honor 8, and now the first steps to log in with gmail account, but i cant continue because wifi is not turnin on!! i cant solve this problem. please help me :(
arberim_d@hotmail.com
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lexi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 21
今までの合計 10,083
