メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
What is customizable in the MacBook Pro 13'' Mid 2012 Unibody.
Hi guys,
I have a mid 2012 Macbook Pro 13'', which is already upgraded with 16gb RAM and 1Tb SSD, but I was wondering what I could do next to reach it's full potential. I actually don't want to pay for a new machine, and as I did not pay for this actual Macbook Pro, I think it would be worth the money to invest a little bit and upgrade it. Is it possible to change anything else, other than what I already did?
Thank you guys for your help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
This is the machine that most of the people at iFixit use because of its repairability. It is also the machine I prefer along with the 15". The most common problem for slow down in it is the hard drive/IR cable. It gets damaged as it climbs over the top ledge and onto the optical drive. To protect it I use a thick padded tape on either side of the cable to prevent the bottom from impacting it. For a while Apple was offering free replacement of this cable. Check the part number on yours and go with the 821-2049. @danj can verify that part number.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cableの画像
製品
$34.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
It depends on what which model you have. If you have the low end model you could swap out the logic board with a high end model (2.5 GHz i5 Vs 2.9 GHz i7). It's a bit of work but thats about it.
MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement and heres the logic board: MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Board
MacBook Pro 13" Unibody (Mid 2012) 2.9 GHz Logic Boardの画像
製品
$299.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Olivier L-Jacob さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 1,320
