メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
Does changing the Power IC affect the data?
Hello guys
i had a problem in my phone after it got dropped , it's turning on and showing apple logo for 10 sec , then black screen and stays black
when in black screen i can see that there is light in the screen from back , means it's working but nothing appears in the screen
so i went to a local Maintenance store , he said he will change the power IC , and sometimes data will be lost , and sometimes it will stay
is it true ? because i don't want to lose my data
thanks in advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
さんによる
My iPhone 6 firstly reboots it self and freezes as well, when I took it to a local technician, he repaired it and it stooped rebooting, but the network stopped working and its freezes sometimes, please does fixing the power affect the network? Is it the power ic that is connected to the network or what?
さんによる
コメントを追加
3件の回答
ベストアンサー
Never heard of such side effect when changing some power component..no direct connection with data storage..unless once screws up the repair and damages the nand. From what you describe it seems it's just the image disappearing after boot or did I misunderstood ? Do you have a Pc to plug in the phone and confirm you can interact with it through itunes after the image disappears..can you confirm that ?
If that's the case it's very questionable replacing the power IC will solve your problem.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
thanks arbman
i connected it to itunes and it is recognized , but it tell me that i have to uptade , when i try to update it gives me error 4013
さんによる
i have no backup for my data
さんによる
Error 4013 seems to be related to a number of issues including damaged nand, damaged baseband, faulty connection to Pc, itunes problem, faulty screen _and_ faulty power IC. You need a good technician who knows his job and finds out what is the real problem before starting changing potentially good components and wasting your money.
さんによる
very thankful
can you tell me when exactly does the phone lose its data ?
さんによる
Nand chips are very resistant and long lasting. But they work on power and can get damaged by an overvoltage or by a short in their power/data lines. That can happen if phone is severely dropped, water damaged or the phone is surcharged by a cheap/unsuitable charger.
Sometimes nand chips die out of wear, but that's pretty rare.
さんによる
1以上のコメントを表示
コメントを追加
If the iphone 6s power ic will be replaced is it possible that the data will be deleted? I don’t want to lose my data. Please answer me. Thank you.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
No, do not worry, if you have an issue with power IC and you get it replaced correctly you won't lose any data.
さんによる
I changed IC some of the data has been recovered but more than half of pics aren’t recovered
Please help me what should I do as pics were not uploaded on icloud
さんによる
コメントを追加
I want to ask a question too. My iPhone 6 went black due to a high power surge. I checked with an engineer and the screen and screen and battery was tested okay on another iPhone.
Please do you think the issue is from the power IC cause that's what the engineer said
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Hesham Adwan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 39
今までの合計 12,726
