メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Google play & gmail apps not working
Hi, tried to uninstall to reinstall cos freezing with Gmail. Probably messed up settings. Factory reset but still same. Blank Play screen, Gmail not letting me add email address. Can get Gmail thru browser so is ok, but Play is just blank. Tried to force stop, delete cache in settings and restarting, but still same. No way to update apps or add more, as no Play.
Any suggestions would be really appreciated :-)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Thanks for suggestion, did download the version I had (5.1.11) from apkmirror.com but when open up, is still the blank screen :(
Would really appreciate any more suggestions, thanks
さんによる
sorry about that... You mean it still just puts up a blank screen as soon as the app opens and doesnt get to the stage where you can enter your google account details?
lets try it again though
[] factory reset the phone. (also remove the SDcard to factor out external hardware issue)
[] uninstall the old google play (if it is there by factory default)
[] try downloading the app from the 3rd party site again.
[] open the app. if you are using wifi and it did not work, try switching to mobile internet, or try switching the device radio off (airplane mode) then back on.
[] ensure your device time, date and time zone are all correct.
[] if still not working try: Settings > Apps > All then look for the force stop button. re-run the app.
[] if still not working, try to see if there are any "disabled google services" in the same menu Settings > Apps > All
let me know is anything works. :)
さんによる
Thanks again for staying with this: an update, did get into Google play online using the 9 dot drop down icon menu with Google. Actually got to see apps, tried to download Facebook but says is already installed ( it shouldn't be as I factory reset the media pad) . Tried downloading an app I never had, gave option to put it on my huawei phone or the media pad. But the media pad icon is greyed over, and says ' no carrier'
Also tried again to manually set up my email in settings, asking did I want IMAP or POP3 Gmail...keeps saying ' IMAP/SMTP service is disabled. Enable the service and try again.'
The manual setup shows 'server: imap.gmail.com
Port ' 993'
Security type SSL/TLS>
IMAP/ path prefix is optional
Maybe this makes it clearer?
Any thought s would be really great again, thanks for spending the time :)
さんによる
Just tried factory reset, can't seem to uninstall the play, only gives options of force stop, clear data, clear cache. Downloaded play again, opened and is a sync circle turning but still blank screen
さんによる
コメントを追加
2件の回答
ベストアンサー
download the old google play from https://www.apkmirror.com/
Let me know if this works
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Followed your suggestion, downloaded the Play 5.1.11 from app mirror. Com, installed it but when opened, is same as before with blank screen :(
Any other suggestions would be really appreciated
さんによる
コメントを追加
root it and uninstall install play store and play services.reinstall it back.settle.no need factory reset.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sinéad Fagan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 25
今までの合計 3,685
