メインコンテンツにスキップ
2008年10月発売。2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duoプロセッサ。
376回答 すべてを表示
Which LCD component to replace due to heat damage?
My mom has a Macbook Pro 15" and she was sitting at a desk that had a candle on it. She opened the lid of the MBP and the back of the lid was over the candle.
The LCD now has a dark patch on the screen. The back panel is not damaged and the picture is still clear in the damaged area but there is almost a shadow where the damage is. I don't know much about how LCD's work but to me it looks a little like the light diffuser is damaged. The dark area is about 2" from the right hand side of the screen and right near the top of the screen. The damaged area is about 1.5" by 1" and oval shaped.
What is the best way to diagnose this? Ideally I would just like to replace the damaged component.
Would a photo help or is my description good enough?
Thanks in advance!
Stefan
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Your description is fine. I admit I've never seen this problem. To make sure I attempt to give you the correct answer, please give the last three letters of your serial number for positive identification of your book. The newer ones use LEDs not LCDs and I believe that is what you will need to replace, I can't think of anything else that might correct it.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Thanks so much. Will do so when I get home this evening. As far as I remember, she got it in July last year but will post the serial number this evening.
さんによる
I am new to macs so I hope I am giving the correct serial number. In the System Profiler it gives me *******21G0. Is this what you need?
さんによる
Apple MacBook Pro "Core 2 Duo" 2.4 15" (Unibody) Specs
Identifiers: Late 2008/Unibody - MB470LL/A - MacBookPro5,1 - A1286 - 2255
Lokks like this is the part you need: MacBook Pro 15" Unibody (Late 2008 - Late 2011) LCD Panel
さんによる
Thanks for the reply. That is the correct Macbook Pro. A little worried about doing the repair as it is listed as very difficult. I have pulled apart normal windows laptops before and been able to put them together with no problem but a mac may be quite different. Looked through the tutorial and it didn't look too tricky. WIll have to think about it.
Thanks again for the help!
さんによる
コメントを追加
回答を追加する
stefan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 3,167
