screen becomes black when half open
G4 Screen turns fully black when half open. Works until half open.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Inverter cable has to be replaced.
このアンサーは役に立ちましたか?
Please give the last three letters of your serial number so we can tell exactly which machine you have and give you directions to the correct part and guide.
The inverter cable is not the same in all ibook G4 models that's why mayer wants your machine serial number. Is it a 12" or 14" model and what's the processor speed (800mhz, 1ghz/1,25ghz/1,33ghz/1.42ghz) ?
+ How to replace the cable:
iBook G4 12" 800 MHz-1.2 GHz Inverter/AirPort Cables Replacement
Here's the part: [リンクされた製品が存在しない、もしくは無効: IF183-000]
Thanks for the helpful information. We will give it a try. I will write again if we have more questions and I will let you know if it works!!!! Randy
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 950
3 件のコメント
Thanks for responding. I am having a challenge getting the keyboard to come off to get serial number. When I get it, I will send the last three letters of the serial number.
Thanks,
Randy
Randy さんによる
Mayer,
Thanks for the answer. Finally got the keyboard off.
It is an iBook G4.
Last four letters of iBOOK number is: BT/LL This is the number on the left side below the ethernet ID. The number that stand alone to the right side ends with S87.
Same symptoms continue.
Thanks,
Randy
Randy さんによる
Apple iBook G4/1.2 12-Inch (Late 2004 - Op) Specs
Identifiers: iBook G4 - Late 2004 - M9623LL/A - PowerBook6,5 - A1054 - N/A
mayer さんによる
