メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
20回答 すべてを表示
MacBook doesn’t recognize new hard drive
I’ve tried 2 different hard drives in my MacBook after I had problems with the original.
When I boot to the USB, disk utility doesn’t see the new hard drive. If I put the old one back in, it will recognize it, but it fails out when I try to format it.
I’m hesitant to blame the hard drives since I’ve now tried 2, but I can’t think of another potential cause.
TIA
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント
The retina models use a solid state drive (SSD) not a traditional spinning disk hard drive (HDD). Are you sure you have a Retina model?
Who's drive are you using? Please tell us the make and model.
さんによる
Yes, it's an SSD made by OWC specifically for this computer. It's an OWC Aura 6gb/s SATAIII. The 2012-early 13 MacBooks have a hard drive that it unique to them and according to the website, this is the one that works.
さんによる
OK, Just so we're clear here you have an Early 2012 13" MacBook Pro not a 13" or 15" MacBook Pro Retina model. Is that correct now.
This is the non-retina model SSD from OWC: MacBook Pro 13" & 15" 2012 (Non-Retina)
This is the Retina model SSD from OWC: MacBook Pro with Retina 13" & 15" 2012 — Early 2013
If you can point us to the unit you bought that would help as well here.
I just want to be sure we are on the same page, as you've mixed terms and have stated different systems. Clarity & consistency helps so we get you aimed correctly.
さんによる
Dan, thanks for helping. The computer is the retina model I posted the question under, and the drive is the correct one for that model. Here's the link to what I bought:
OWC 240GB Aura 6G Solid-State Drive for 2012-2013 MacBook Pro with Retina display. https://www.amazon.com/dp/B00LPR25RI/ref...
さんによる
コメントを追加
2件の回答
ベストアンサー
I found the answer thanks to OWC's very helpful tech support.
The drive needed to be formatted for Disk Utility to see it, so I did that through the terminal and it worked great.
It didn't make sense to me that Disk Utility wouldn't see the drive, and that //diskutil list disks// would, but there it is.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I know this is old but just in case you get this, could you put in a link to what OWC said to do, specific commands to check and format the new disk? Thanks.
さんによる
コメントを追加
OK, I think I figured out the problem here! 2013 was a transitional year. For reference here's the three models produced that year:
If you open each of these links and jump down to the 'Storage Dimensions:' line you'll see the early model offers a custom 6 Gb/s mSATA interface, whereas the other two offer a custom PCIe 2.0 x2 interface.
I'm suspecting you really have one of the late 2013 models which is why the SSD you got won't work.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's definitely an early 2013. I checked the serial number, and the PCIe interface physically is much different. A PCIe drive would not fit where the drive in this computer goes.
さんによる
コメントを追加
回答を追加する
Mike Stone さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 4,671
