Why is iPhone 5s restarting after some minutes of usage?
iPhone 5s turns on well but restarts after some minutes of usage, had a problem with high electric current once and since then this issue. what is the possible cause ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Has battery been unplugged it replaced before.
Sounds like a capacitor or two right above the battery connector got knocked off or damaged causing the battery not to be read correctly.
このアンサーは役に立ちましたか?
Can you elaborate more on what you mean by high current problem? Sending too much current through an electronic device can burn out resisters and blow out capacitors, which could be the problem. Other than that, the battery could just be getting disconnected. The panel covering the battery connectors is pretty important, so be sure that it isn't coming off (but also be sure you don't put a wrong screw into the board). Good luck
このアンサーは役に立ちましたか?
So am I supposed to change the whole board or not ?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 84
