メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
iPhone will not charge after updating to iOS 11
When I updated to iOS 11 (the full release not the beta) my phone battery, like everyone else, is dying unreasonably quick. If the phone dies completely the phone takes ages to turn back on while charging. Currently I have had the phone plugged in for approximately 3 hours and it has not turned on. When it is plugged in and I press the home button a battery with a read line will display, if it is unplugged that same battery with red indicator line will display but also shows a lightning charger to prompt the user to plug it in.
I have tried multiple cables and multiple wall adapters (all of which I have tested on other devices and they work) with no help on my phone.
I have tried holding down the home button for 15 seconds, the lock button for 15 seconds and both for 15 seconds with neither doing anything.
At this point, what can I do to get this thing back up and running?
As a side note I have updated to 11.1 yesterday with no help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
has it ever got the battery replaced since new
さんによる
Super Su is one of the best app to root apps. SuperSU allows latest management of Super user access rights for all the apps on your device that need the root. It has great importance in the field of international security and it has great influence. It doesn’t contain any ads and great compatibility. SuperSu is a very amazing tool for Android developers and gamers.
https://supersuapp.com
さんによる
コメントを追加
6件の回答
ベストアンサー
Have you tried restoring your iPhone and see if that helps on iOS 11? Make sure to make a iTunes backup before restoring your phone to avoid losing data on the phone, so that you can restore the iTunes backup of the phone.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Have checked the charging port? Clean the charging port with a toothpick then charge it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
When plugging your iPhone or iPad into the wall outlet or computer, you find that it is not charging. Why? This is a common issue many users complained about. Before you changing a new battery, there are some solutions that are worth-a-try.
1. ALWAYS use official Apple-matched chargers. If you use some cheap cables that are low quality, you’ll usually encounter an error that the cable is not certified on the iPhone (or iPad). This may be what is causing the iPhone not charging issue.
2. Hard reset your iDevice. Press and hold down the On/Off button > While continuing to hold the On/Off button, press and hold the Home button > Keep holding them until the screen turns back on and shows the Apple logo. For iPhone 7 users, please press the Home button and the Volume down button.
3. Check the lighting cable for damage. Most of us have experienced a broken charging cable at some point. The exposed internal wires are not safe to charge your iDevice and that might be why your iPhone or iPad won’t charge when plugged in.
4. Change the wall outlet or Apple lighting cable if available.
5. Turn off your iDevice and charge it: Just Press and hold the Sleep/wake button > Turn off your iPhone/iPad when you see "Slide to power off" > Charge your iDevice now.
6. Restore your device running iOS 11/11.1/11.2/11.3 with iTunes. Firstly, backup your iPhone or iPad with iTunes, and then restore it from the backup you just created.
Part 2. How to Fix iPhone/iPad Charging Slowly Issues After iOS 11/11.1/11.2/11.3 Update
Is your iPhone or iPad charging slower than usual after download the new iOS? Get some quick tips to get your iPhone or iPad charged faster in this part.
1. Clean up Charging Port of Your iPhone or iPad. After a period of use, the lightening port of your iPhone or iPad may get full of dirt or dust that reduces the charging speed of your iDevice. Firstly shut down iPhone/iPad and then use toothpicks or dry soft toothbrush to get all the dirt out of the charging port.
2. Use an iPad Charger for iPhone. To charge your iPhone quicker you can try using an iPad charger if you got one.
3. Turn on Airplane Mode and Turn off Wi-Fi While Charging. In this way, you won’t be able to make or receive calls, messages, and notifications or connect to network, but this makes battery charge faster.
4. Turn off iPhone/iPad While Charging. This is just like the third method, you can charge faster by turning off your iDevice while charging, and you can try this method during the night when you won’t need to use your iPhone or iPad.
https://tutuappapkd.com/
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Trust me, it's not dirt in the port. It's the update. Happened to my 5S, and my SE. Recovery mode did nothing. Restore, update, all the same. I had to replace the battery in order to get the phone to turn on in limp mode. Still would not charge the battery. I have a feeling that the update somehow caused the charging circuit to overload. This was on apple certified charger. How convenient that this happens after after warranty expires. Never abused the phone, nor left it in humid environments. I bet if i put the battery in another phone it will charge until that update happens. Planned obsolescence. Apple's really trying people with their shoddy product contests. After trying everything, wasting 8 hours on these bricks, I'm done with their abuse for not caving to buy another near-future paperweight. Sorry I couldn't provide a solution, but at least you can save some time not wondering if it's something you're not doing right. Daylight savings time cannot offset how much time has been wasted on this issue.
さんによる
コメントを追加
It is possible that the software upgrade used a lot of battery power and your battery needs a break to cool down before it can work properly again.
Try removing the battery and letting it cool for about 30 minutes. Then put it back in and see if the problem persists.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Aptoide is a great app for ios, through which any app or application can be downloaded to free on ios device. We will download you for Aptoide iOS on our site. From here you can easily download it.
The Aptoide iOS device uses its own operating system. ios users use iOS stores to download the app. The Aptoide App has all the application data, which is not on the iOS store. In this post, we tell you how you can use Aptoidefor ios and how to download it for your ios device. We will download Aptoide For iOS, iPad and other iOS devices. This app is completely free and it is not taken in any way by any monthly/yearly charge. This app is a third-party app store that allows you to download thousands of millions of apps. Aptoide APK is specially designed for the Android user, but you can also use it for the ios device. It works on all kinds of devices.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Cory Mynhier さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 4,227
