iPhone 6 battery drain after screen replacement
Hi,
I have recently got a customers phone that needed a screen replacement because it had a cracked screen. I have done this many times, however, this time the screen I ordered had white lines coming down from it. I thought it was a faulty screen and sent it back and bought a new one. The new one works perfectly but the battery suddenly drains every quickly. I have done a few tests but I can't figure out what is wrong. I would be very greatfull if someone can help me out here.
Observations:
- Checked anohter screen, still draining
- Found out that phone has lots of heat at shield below connectors
- Looked under microscope and not damage to connectors or filters
- Even when screen unplugged phone drains battery and is warm
この質問は役に立ちましたか?
4 件のコメント
take the shield off and see if you can detect where the heat is coming from
daniel さんによる
Ok should I take off the shield and let you know
Tom さんによる
Hi Tom, did you manage to fix this issue? I seem to have the exact same problem. If so, what did you do to fix it?
Theo Warrender さんによる
No sorry, I wasn’t able to figure out what was wrong. I have no clue what could have gone wrong but maybe whilst unplugging some of the connectors it’s possible that I might have damaged a chip or component on the board.
Tom さんによる
