My retina screen has a white stain inside.
I cleaned my screen with a damp cloth, and this stain showed up. Why is that?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Liquid has leaked behind the screen and stained the backlight sheets. If you're lucky it might dry out, but in most cases it will not; so you are either stuck with it or you can replace the whole assembly
このアンサーは役に立ちましたか?
How come it leaked there? Was it damaged before which left a tiny gap or something?
Liquid will leak between the screen and rubber bezel if there is enough liquid
I think I'm lucky, it dried out.
Hi!
The same thing happened to me when I was cleaning off the residue of the peeling antiglare coating with various solvents (thank you, Apple)… Anyway, it is hot now so I hope it will dry on its own, but:
If I take off the display assembly and peel off part of the rubber bezel, how safe it is to ‘blow-dry’ the affected corner? Would it just cause more damage if I blow hot air over the sheets?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 965
