メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
My iPhone is disabled but wont connect to the internet
my iphone 4 is locked out for about 45 years, i have tried to wipe it through itunes but it either asks for a password which i do not remember or it wants it to be connected to the internet which is not possible
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
@ambssharriss how did you do this "have tried to wipe it through itunes"?
さんによる
コメントを追加
3件の回答
ベストアンサー
If you are lucky you may have cellular data enabled and date and time set to change automatically.
In result you should be able to use an activated working sim card with or without mobile data to syncrhonize the date and time and fix the locked for 45 years issue.
This usually occurs when the battery has been flat for a long time or was unplugged resetting the time on the phone to 1/1/1980 which is the system default time.
Otherwise if you can't get the date and time synced then unfortunately you will need to restore the phone through iTunes.
To restore the phone via iTunes you simply switch the phone off, hold the home button and plug the iPhone usb cable to the computer to the phone.
Keep holding the home button until you get the iTunes logo.
Then open up iTunes and click restore.
Depending on how long it takes to download the firmware to restore the phone the phone may kick itself out of recovery mode and then you will need to put the phone back in recovery mode again using the above steps before the download finishes to ensure the restore is perform successfully when the download finishes.
You will most likely need to enter your Apple ID and password linked to the phone during the setup activation stage after completing the restore of your iPhone.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I dont Have a sim i cant take it out of another phone the phone is important to me
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@benjamen50
@benjamen50
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
amber harris さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 16
今までの合計 4,784
