Why is tape/glue strip so bad?
Why is tape/glue strip so bad. It doesn't stick even after cleaning with alcohol.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Alcohol typically ruins adhesive. Ifixit recommends replacing those strips:
このアンサーは役に立ちましたか?
I would add you need to apply pressure in one direction around as you apply the cover glass and keep it under pressure for a good 12hrs to let cure. Here's a good vid of us checking out different methods: EP65 Conclusion to the iPad Sealing Workshop at the iFixit Unconfrence
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 63
