メインコンテンツにスキップ
Repair guides and troubleshooting information for microwave ovens.
759回答 すべてを表示
Why is my microwave immediately shutting down?
Panasonic Over The Range Microwave Oven Model NN-P295 shuts down immediately no matter what program is selected. It started doing this after the exhaust door at the top was pushed closed while it was running. I will try to add pictures showing the door st the top of the microwave.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
There is a switch located behind that vent. There is a possibility that by forcing it shut you threw the shaft that opens and closes the vent out of allignment with that switch. Or the motor to the vent has been damaged or the shaft it self broke. Can you here any kind of motor attempting to open the vent. Does the vent still open?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Also did it continue to run after the vent was forced close?
さんによる
The vent still operates so it looks like all is OK there. The vent closes right away .
さんによる
コメントを追加
回答を追加する
Bruce Herbert Maynard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 147
