My charger portal seems to be broken
Hi it looks as if something has broken off of my charging portal can I get it fixed
@noem2015 disassemble your Kindle. Follow this guide. You should check the solder connections on the micro USB port. It is very likely that they have either come totally off the motherboard or that they have micro cracks. It might be possible to reuse the old connector and resolder it, or you may have to find a new connector. If you need a new one, you could check mouser.com or digikey.com for a micro USB that fits the dimensions of your Kindle. Check on here about how to fix this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 77
