メインコンテンツにスキップ
2015年3月のアップデートではアップルの13インチMacBook Airは第5世代Intel Core i5またはi7プロセッサーを特徴としており、これによりわずかな性能とバッテリーライフの向上がされました。
612回答 すべてを表示
Can I upgrade my new MacBook Air 2017 from 128gb to 256 gb ssd
Hi, I have a MacBook Air 2017 and I want to upgrade it's ssd from 128gb to 256 gb. Can I do that? And, I also have crucial 2.5 256gb ssd drive(is it compatible with Apple Mac air). Which tools I will need to do this, thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 9
3 件のコメント
If you use an aftermarket part, won't it void the warranty?
さんによる
what warranty at this point, they dont sell this model anymore, its been 3 years since this has been discontinued plus its now illegal to void warranties in this way since the FTC is now enforcing the Magnus & Moss Warranty Act
さんによる
If there may be any app that work ideal in time period of excellent and subtitles, it’s not anything cucotv apk. Yes, you could now watch all of your favorite movies and collection in your very own language. You have the choice to select the language of the subtitles at the start of the app release. https://cucotv.com/ Otherwise, you may visit settings of the app after which go to subtitles phase to choose the language. So, you have got one of a kind methods in which you could pick and configure the subtitles of any movie or a show.
さんによる
コメントを追加
2件の回答
ベストアンサー
Yes you can upgrade your current SSD to a larger unit. Here's the part you'll need to get:
FYI: the newer 2017 model is only a CPU swap out to a slightly faster chip. Its the exact same system otherwise.
このアンサーは役に立ちましたか?
スコア 8
4 件のコメント:
Hi! I believe it's necessary to back up whole system before changing SSD. Can you explain how please?
Thanks
Tomas
さんによる
There are a few different ways you can do this:
First create an OS installer thumb drive following this guide: How to create a bootable macOS High Sierra installer drive This will allow you to install a fresh OS on the new drive.
As far as your data you could reuse your old SSD using the special case you can get with either SSD supplier or just make a full backup onto an external drive using TimeMachine then restore onto your new drive.
さんによる
Hello Dan,
Is there an upper limit of the size of SSD I can use for MacBook Air 2017, please? Thank you, from Ming
さんによる
These are custom drives so it is what it is! 2 TB appears to be the largest offered.
Don't forget the larger the drive the more power it needs, so going larger than 2 TB will likely effect your systems run time.
さんによる
コメントを追加
You can use a Samsung SSD’s with an adapter. It has worked for a handful of users.
Apple will of course tell you otherwise. And their drives are slower.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
You can also use your current Crucial SSD by using an adapter from Sintech. As long as your SSD fits the form factor for your MBA (M.2 2280)
さんによる
Can you pls. post the description/link of the sintech adapter that worked for you?
さんによる
@tshiv - I really don’t recommend using these adapters.
Look at it this way is a rope which is a single line safer than one made up of a string of shorter lengths?
Every connection within the pathway introduces a possible failure. As I stated there is a balance between size and stability of the system.
Stick with the original Apple drives or use the custom SSD from OWC or Transcend as there is some other issues within the interface that an M.2 drive with an adapter can’t gain.
さんによる
コメントを追加
回答を追加する
parvindersingh1313 さん、ありがとうございました!
統計データ:
過去 24時間: 9
過去 7 日: 43
過去 30 日: 183
今までの合計 108,209
