iPhone Replaced Battery now sleep/wake button and video mic won’t work
Recently replaced my iPhone 6 battery. Now the sleep/wake button won’t work as well as faint-scratchy/no sound recorded on videos.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ok, I should've just posted my answer earlier. So you've damaged some stuff while doing your repair. The power button, which is connected to the volume/mute, which you'll have to remove the battery and the logic board. It's a pretty big repair. Youve also likely damaged the front camera flex assembly. Not that big of a job. I mean you should check that and make sure you properly seated the connections. But likely you'll have to order new a new one
製品
$19.99
製品
$9.99
ガイド
難易度:
難しい
1 - 2 hours
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 8
過去 30 日: 12
今までの合計 223
2 件のコメント
Does you volume/mute switch work?
iMedic さんによる
Yes it works.
eric collins さんによる
