メインコンテンツにスキップ
Issues with Home and Power Button
I replaced the glass digitizer. In the process accidentally ripped off the Wifi/Bluetooth antenna. I replaced that and the glass but for some reason when I reassembled everything, the home and power button are not functional (only to turn on but not to wake or sleep). The volume and mute button still work fine.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
when you ripped of the antenna are you sure you didnt rip anything else off
さんによる
From what I can tell, no nothing else looks out of sorts. Would you like pictures to make sure I'm not over looking anything?
さんによる
コメントを追加
2件の回答
最も参考になった回答
if the volume buttons work but the power button does not you have likely torn through the cable on the top right hand corner of the iPad when letting the digitiser, it can be replaced following this guide..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
The home button is not working either. Do you think I may have messed up something there as well? This is my first time attempting to repair an iPad. My apologies.
さんによる
コメントを追加
You can also turn off the lock/unlock feature by going to Settings - Display & Brightness - Then turn off Lock/Unlock. This should allow your sleep/wake button to work again.
If you want to actually fix that feature, you will need to replace the power/volume flex as rayeasom mentioned.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jacob.v4 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 76
