メインコンテンツにスキップ
Appleの2016年ラップトップラインアップの最新モデルは、プロフェッショナルユーザーを対象としています。 15インチ、2880 x 1800 Retinaディスプレイ、クアッドコアIntel Core i7、256 GB / 512 GB / 1 TB / 2TBストレージオプション、16 GB RAM、およびTouch Barを搭載したキーボードです。
260回答 すべてを表示
Possible to save MacBook Pro display connector?
Spilled yogurt into the right vents, and it got into the display connector. Logic board and everything else seems fine (yogurt never got there).
Here's some images: https://imgur.com/a/zFL48
What's my best option?
- Clean it with alcohol?
- Order a replacement screen (they go for around 300-400USD)
- Send to apple and PRAY they don't charge me >1000USD (no AppleCare :( )
I tried to turn it on after 48h in rice, and it did work, albeit with weird transparent bar going on and off every few seconds.
Can I test that the screen connector IS the problem?
Any help is greatly appreciated in this time of frustration.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Before you send it to apple at least try plugging it into an exterior monitor. This way you can see if it is the connector going to the screen of your mac or if it is something else.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Can I do it without connecting the macbook screen?
さんによる
If you have an adapter for HDMI such as the lighting cable to HDMI similar to what a person would do if they were going to dock it at a work station. Then use the keys at the top of the keyboard to switch the display.
さんによる
Yeah I got a hyperdrive with HDMI. Thanks, will try it out.
さんによる
コメントを追加
Sorry Rice is a myth! It does not work on yogurt only water ;-{ And it only pulls moisture out of the air not wetness like a spill. Besides, just like when you spill your coffee the solids will still be left which can be more harmful concentrated. If you had opened it up sooner you likely would have saved it.
While connectors on this side look bad how does the main logic board connectors and the ribbon cable? If they are clean you have a chance here in just replacing the display assembly. If they look as bad then you may need a new ribbon cable and possibly a new logic board as well. FYI the connector is hidden on the backside of the logic board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Austin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 922
