メインコンテンツにスキップ
The Acer Spin 5 is a mid-range Windows 10 laptop with four different screen orientations that allow the laptop to double as a tablet or movie streaming screen by rotating the display.
Why did applications stop opening on my Acer Spin 5?
Downloaded applications such as Kakaotalk and Discord suddenly stopped opening up when I double click / run it as an administrator. These apps were running without problems a couple days ago. I have not made any updates or changes to my laptop.
When I double-click on the applications, the cursor wheel spins and then stops, but no application is opened.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
i want to install Microsoft office and it requests a product key
what can I do ?
さんによる
コメントを追加
1 件の回答
Kill the Discord task
  1. Press Windows key + R.
  2. Type cmd and then click OK.
  3. In the cmd window that appears type taskkill /F /IM discord.exe.
  4. After the process finishes, relaunch Discord.
Now everything should work fine. Additionally, you can do the same thing by using Task Manager: press Ctrl + Alt + Del > select Task Manager > in Task Manager find Discord > click on it > click End Task > relaunch Discord.
Does Discord keep freezing? Here’s how to fix it permanently
2: Clear AppData and LocalAppData
  1. Close Discord using the solution above.
  2. Press Windows key + R and type %appdata%. Then hit Enter.
  3. In the new window that appears, find Discord folder and delete it.
  4. Relaunch Discord.
You can also stop Opening discord at starting this will make a fresh open every time, So that you won’t face those issues.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dana Hong さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 288
