Vacuum not sucking anything up?
The vacuum is clearly powered on but whenever I go over a piece of debris it won't pick it up. What do I do?
Weak suction is sometime due to a faulty brush head. Clogged debris prevents it from revolving properly. You may have to reach into the brush head to remove any debris. If you have checked the brush head and everything seems clear the issue may be the motor. If this is the case consider a motor replacement. For instructions on a motor replacement, see the trouble shooting page Shark Navigator Lightweight Upright Troubleshooting
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 900
2 件のコメント
student question
mayer さんによる
Debris only collects in the little space with the big white filter, how do I fix this
karen.johnson649 さんによる
