メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
Mobile data Problem always E
My Sim signal is strong my fellow iphone 5s user in the house has a lte/3g working even outside my iphone is just E ihave no prpblem sending calling etc .Just the mobile data is weak my internet connection is strong also what to do i already reset it still doesnt work what to do pls
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Thanks it works
さんによる
コメントを追加
2件の回答
ベストアンサー
Try both of these
Settings --> General --> Reset Network Settings
Settings --> General --> Reset all Settings
What model iPhone 5s do you have?
What is your carrier?
Has it worked before?
このアンサーは役に立ちましたか?
スコア 3
9 件のコメント:
Im from Philippines its always E sometimes its 3g but if it goes 3g it will not work the data just works on E i tried putting another sim nothing wprks i also tried my sim to other iphone 5s and it goes LTe/3g what to do
さんによる
Is the iPhone 5s you are using from the same place as the other iPhone 5s? Without knowing the model of your iPhone 5s and which cell phone company you use, I can't help further. Different region iPhones have different LTE band support.
https://support.apple.com/kb/SP685?local...
さんによる
Ok thanks :) so definitely this is not a hardware issue ?
さんによる
Mine is a1533
さんによる
I didn't say that it wasn't hardware. What cellular phone service are you trying to use for LTE? Different Cell phone companies use specific LTE bands.
Have you checked LTE status in Settngs --> Cellular --> Cellular Data Options
さんによる
4件以上のコメントを表示
コメントを追加
You could check the apn. But I'm just going to guess you've damaged the Lightning dock, using aftermarket cables. I would replace the lighting dock and see if that improves the situation
Parts
iPhone 5s Lightning Connector and Headphone Jack
Labor
iPhone 5sのLightningコネクターの交換
Replace a lightning connector or headphone jack compatible with iPhone 5s. Includes cellular antenna and microphone to save time during the repair. Models A1453, A1457, A1518, A1528, A1530, A1533. Part #821-1596-A and Part #821-1667.の画像
製品
$24.99
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
DOes lightning dock affects the mobile data ?but my wifi connection is strong and definitely signal the one that is definitely hurting me is that weak mobile data
さんによる
What is the cellular service company you are using or roaming with? You never answered this question.
さんによる
Ok, if you really don't want to tell me what carrier you have, that's fine. According to this list, there is no LTE phone company in the Philippines.
https://en.wikipedia.org/wiki/List_of_LT...
If you are using a Filipino SIM card, it is highly likely you cannot get LTE simply because of the phone company.
さんによる
Im using smart im sorry but it ahould be 3g
さんによる
Ok, see if your APNs are set correctly.
Smart has some FAQs on things to check.
https://smart.com.ph/About/our-network/3...
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Fixie さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 43
今までの合計 26,056
