メインコンテンツにスキップ
Waterproof action camera (model no. CHDHS-101) released by GoPro in July 2015. The Hero4 Session shoots 1080p video and 8MP stills.
24回答 すべてを表示
Looking for the internal lens assembly. I have it completely apart.
I smashed the internal lens of my go pro session 4. I have taken it apart and don't know where to purchase the lens assembly. I figured the lens assembly and sensor will need to be purchased together because the lens is glued into the assembly probably for focusing. I was able to get it screwed out but figure there will be no way to refocus it with a new replacement....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
I was wondering also if one of the two will work since the sensor size is supposed to be the same:
GoPro Hero Lens
[リンクされた製品が存在しない、もしくは無効: IF300-109]
I am about to receive a cracked lens Hero Session and will followup with what I find.
You should be able to refocus by using a calibration target to make sure image lens is screwed to correct position for proper focus, then maybe hot glue in place:
http://www.vision-doctor.com/en/line-sca...
GoPro Hero Lensの画像
製品
GoPro Hero Lens
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
So, were you able to replace the lens?
さんによる
Yes, in regards to the outer lens. No, wasn't required regarding the inner from what inspection I've performed so far.
I found the outer lens destroyed and the inner lens wasn't in as bad of shape as the listing noted. I replaced the outer lens, invested in a aluminum 52mm lens adapter, a 52mm CPL and lens cover also. I haven't performed a thorough image analysis though.
Thankfully, from what I can tell that appears to be imperfect on the internal lens from a visual inspection... isn't observable in the images from a quick review.
さんによる
コメントを追加
回答を追加する
Josh さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 627
