メインコンテンツにスキップ
MacBook、MacBook Pro、MacBook Air用のAC電源アダプタです。引っ張られても安全に外れる整列式の磁気コネクタを採用しています。第一世代 (2006-2012)のMagSafe充電器は、コネクタがやや太いL字型になっています。45W、60W、85Wの3種類があります。
65回答 すべてを表示
Broken Resistor/capacitor - Values on PCB MagSafe 45W-PA-1450 (BOM?)
Hi,
Luis from Germany,
I'm working on a genuine Apple MagSafe 45W PA-1450 charger as it won't charge by system anymore after 4 repairs on the same cord. I have disassembled it once again, I'm getting the right voltage on the output of the PCB.
A visual inspection shows that the big resistor of the high voltage section and the capacitor next to it (see pics) where damaged.
Does any one have the teardown / BOM / PCB component values of these 2 components?
The rest of the components seem to be good. I have the time and the right tools to fix this charger: solder smd, measure (100Mhz scope/multimeter/hot-air/etc.)
Big thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント
Halo Dan, thanks for your fast answer and your guidance .
I´ve experience on designing 600KHz Switching power supplys, so no problem to deal with the HF/HV.
A photo of an open charger (MAGSAFE 45W PA-1450 A1374) might work as well for me to identify the resistor / fuse, but of course somethoing more technical will be welcome.
Thanks!
/l
さんによる
Sorry guy we don't try to repair them and we only have 65 Watt units
さんによる
my name is JORGE CRUZ of the Mexico, C=74uf
さんによる
I have an alternative question: does anyone know which of the pins are for the positive or negative ends of the cable side? I took the old one’s off to replace them and now I do not know which one is which. Some help would be greatly appreciated!
さんによる
コメントを追加
2件の回答
最も参考になった回答
@lurgaci Apple may not but iFixit does. After all, the purpose of this website is to empower others to fix their devices. Good thing I am a hoarder and keep stuff after I tear it down :-)This is the part you are looking for
After checking it with my meter it shows to be a 0.24ohm resistor.
The capacitor shows 74 uF and that is mounted to the board. Can't get to my ESR tester right now but that should still work out for you.
このアンサーは役に立ちましたか?
スコア 5
7 件のコメント:
Halo Oldturkey,
thanks a lot for the fast and clear answer
Thats what i need for now to try to fix this unit.
Hope you have a long great weekend!
/l
さんによる
Luis viel Glück mit deiner Reparatur.
さんによる
One more question:
Do you think this ceramic capacitor its a 70µF, maybe ~70nF?
When I took it out I was measuring 10nF, but might have been damaged...ç
Could you test it with the ESR?
I will get the resistor hopefully next monday...
Vielen dank Hern Alter Truthahn!
L
さんによる
@lurgaci Give me a bit of time since I am at work right. Nach der Arbeit werde Ich dehn Kondensator noch einmal messen.
さんによる
@lurgaci just double checked and got the same results 74uF
さんによる
2件以上のコメントを表示
コメントを追加
Sorry Apple doesn't offer parts or any info for their chargers.
Frankly, given the high voltages and the risks of fire I don't recommend trying to fix them. Besides the personal risks you can also damage your system as well here!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Lurgaci さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 25
今までの合計 1,882
