メインコンテンツにスキップ
TI-84 Plus calculator support.
37回答 すべてを表示
Why does my TI-84 plus calculator say RAM cleared?
When turning on my calculator, the screen displays "RAM cleared" and "press alpha F1-F4 to locate shortcut menus." After pressing alpha F1-F4 there is no change in the display and none of the buttons appear to work or change the display. The only way to get the display off is to pull out the battery :( Any ideas on how to fix this?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi @jackicca ,
When you say "pull out the battery" do you mean the 4 x AAA batteries?
Have you also tried removing/reinserting the small backup button battery (designed to retain the memory when the main batteries are changed) as well as the main batteries, to see if this resets the calculator and clears the problem?
Here is a link to the ifixit TI-84 Plus Silver Edition Backup Battery Replacement which shows where it is and how to do it.
Hopefully this is of some help
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Jackson Chen さん、ありがとうございました!
統計データ:
過去 24時間: 12
過去 7 日: 99
過去 30 日: 460
今までの合計 23,734
