Why isint my keyboard responding?
I wanted to clean the inside of my Mac, I put everything back into place, I turn it on and only the power button works. I checked the connection and it was good. Any help?
If you took things out of your Mac to clean it, you may have forgotten to reconnect something during reassembly. Without knowing exactly what you took out of the Mac, my immediate suggestion is to go back and ensure that everything is connected properly.
このアンサーは役に立ちましたか?
I went back to open it, and I didn't connect one of the ribbon cables for the keyboard right. Thanks
That'll do it! Glad to see it worked out alright! :D
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 77
2 件のコメント
How did you clean your system? Did you use a can of can'ed Air or a Vacuum? Did you use any liquid cleaners?
Dan さんによる
I only used canned air.
Charles Bejarano さんによる
