メインコンテンツにスキップ
モデル番号A1708/EMC2978ー2016年10月発売。このエントリーレベルのMacBook Pro にはこれまでと同じファンクションキー(OLEDTouch Barとは反対)が搭載されています。ファンクションキーモデルにはIntl Core i5と2つのThunderbolt 3ポートが付いています。
216回答 すべてを表示
Looking for an enclosure for MacBook SSD?
So my Macbook Pro Late 2016 has recently died from a water spill, I'm trying everything but I think the logic board is fried. I'm wondering if there's a way to potentially retrieve my data from the SSD, since it's able to be removed, and if so which enclosure or reader would be best for the one in this model (Late 2016, A1708). I've been looking around online and I found some for earlier models but I want to be sure before I order which one is right for this model. Any suggestions or recommendations would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Oh No! Not good...
OWC is one of the few companies which make cases to house Apples custom SSD's. Sadly, the new function key model uses a still newer physical connection than what OWC offers in their cases so there is no means to gain access without leveraging a second MacBook Pro 13" Function Key system to host your SSD (swapping them out) then copy off your stuff to an external drive then pop the original SSD back in (if its larger).
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Dang, any update on if there’s any enclosures about for the SSD now?
さんによる
Sorry no external case
さんによる
コメントを追加
I can help you getting your data of the device if you send me the ssd as I can put it in my macbook and send you all the important stuff you want :-) Sounds better then spending a lot on a new macbook just to void it's waranty because of swapping it's ssd out with the one of your liquid damaged macbook right?:-)
Cheers
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Sorry but I really don’t feel comfortable sending a complete stranger on the internet my hard drive with my personal information on it...
さんによる
No problem, was just trying to help out. Maybe ask some friends with an similiar device?
さんによる
Musti, do you know that this will actually work?I have the same story as OP but I have another macbook pro coming in the mail so I want to know if you have tried this before and that I can actually access the data on the drive?
さんによる
Looking for an enclosure for this drive to get my data off as well. Any luck?
さんによる
コメントを追加
回答を追加する
Taylor Manning さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 11
今までの合計 2,364
