メインコンテンツにスキップ
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99回答 すべてを表示
Display is tilted to the left about a half inch?
ok so i have two 24 inch cinema hd displays, and they are both on a flat surface next to each other and one of the displays is tilted about a half inch to the left. In other words the bottom left corner of the display is closer to the desk then the bottom right. How do i fix it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
No damage at all, it makes me mad now that i notice it. I can always take the stand apart and give it a little tweek with a bar to bend the stand back.
さんによる
コメントを追加
2件の回答
最も参考になった回答
You can replace the stand, here's how: http://docs.info.apple.com/article.html?...
or you can place a level on the top of the frame, tilt it to the right and use enough playing cards under the left hand side of the stand to keep it in place. It's kind of concerns just why it's tilting. Had it been physically damaged?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Lay it flat on it’s back on a hard and level surface and leave it for several hours or half a day. Don’t forget to temporarily re-route the cables so they won’t be crushed by the stand. This way the hinges would work themselves back to the original position by the pressure of the display’s own weight (provided that the stand itself is not bent in any way). Worked on several 27” Thunderbolt Displays I’d encountered with this tilting issue (4 out of 5). Hopefully this method works for you.
Ron
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
frank guido さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 1,359
