メインコンテンツにスキップ
日本国内では2017年7月13日に発売されたNintendo 2DSの後継モデルのハンドヘルドゲームコンソールです。海外では「New Nintendo 2DS XL」として販売されています。
20回答 すべてを表示
Why is my joystick stuck scrolling?
Whenever i turn my 2DS on, the home menu wont stop scrolling to the left. How do i fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
If your device thinks you're scrolling with the joystick even when you're not touching it, you may have one of the following issues: un-calibrated joystick, dirty joystick, or a broken joystick. Fortunately, these are all repairable issues.
Calibrating your joystick can be done through the device settings without any disassembly.
If calibrating the joystick doesn't solve the issue, please refer to the linked guide below:
Joystick Repair Guide
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My brother’s 2DS XL is drifting to the point where it’s not calibratable every time it keeps moving to the bottom right I tried taking it apart and checking the connections and it’s in there correctly but It still wants to drift any ideas (ps I previously had to take it apart because he broke the wifi cable and top screen so I could repair it fyi pain in the *** it took me at minimum 1-3 days to fix cheap repair too all I did is go on Amazon by a top screen [around $27] I already had a screwdriver for it but it also came with one [tri-wing screwdriver] he broke his previous 2DS XL Pokeball edition so I have replacement parts that work any ideas)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I also can’t get my hands an compressed air the only air I have is in a ball pump (hand pump) but I have rubbing alcohol (isopropyl alcohol)
さんによる
コメントを追加
回答を追加する
Tim Newman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 12
今までの合計 2,918
