How do you repair torn ground foil on the logic board?
Just received the new logic board for my 5.5 and was able to take everything apart following the how-to document. My only issue was that the Foil removal from the old bard and re-install on the new board was not discussed...or I missed it. Of course I was not careful enough and the the thin lead that goes to the case for ground has torn.
How do I fix it?
As a dosumentation suggestion:
Looks like either here:
iPod 5th Generation (Video) Logic Board Replacement
or at Step 19 (Or new Step 20), we need to instruct on how to remove said foil.
I found that after mistakenly pulling the ground tab piece (which casued the foil break) that peeling up on the round (white underlayment) from the base-end of the logic board is the best method as it does not put stress on the foil itself.
この質問は役に立ちましたか?
