usb port needed for rca rct62o3w46
have broken the usb port on machine can they be replaced and if so where would i order one onslow
@onzie it is soldered to the motherboard. Use this guide RCA Pro10 Edition Power/Volume Buttons Replacement to get to the board. Disconnect all the ribbon cables and remove the screws. Remove the board. Now you will need to desolder the old connector. Then replace it with something from here.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 45
