メインコンテンツにスキップ
Portable wireless speakers from Logitech released in 2013.
Logitech Ultimate Ears UE Boom bad battery symptoms
UE Boom was handed down to me. Original owner said it "stopped working".
Plug in micro-USB cable, and saw a white LED light up for one second. There has been no other reaction since. No smartphone has been able to discover the Boom.
I believe what happened did so suddenly. I am not sure if the Boom suffers from a dead battery or other problem.
I will continue to wiggle the USB cable, but I'm not expecting changes in behavior
What else should I examine if/when I take the Boom apart?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Are you using the charger & cable it came with? Try another cable.
さんによる
コメントを追加
2件の回答
最も参考になった回答
lkvee start by replacing the battery. Use these guides UE Boom for that. Even if this will not work immediately it will provide you with a known-good point to start more troubleshooting should it be necessary.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I've read that UE Boom has a good support team. Contacting them would be the next step I think.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
lkvee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,076
