メインコンテンツにスキップ
2012年6月発売。Core i7プロセッサ 、Turbo Boost / 最大1 GB DDR5 Video RAM
596回答 すべてを表示
Best format for secondary harddrive (NO OS installed) APFS or HFS+
hi there
I would like to know regarding format on my secondary hard drive on my MacBook Pro. At this moment my main SSD drive is on APFS format & my secondary drive I'm using 2TB Seagate Firecuda SSHD. Should I format the SSHD into APFS too like my main SSD drive or just leave it as it is MacOS Journaled? There's NO OS/OSX/APPLICATIONS in that secondary drive 2TB Seagate Firecuda SSHD.
EtreCheck Report generated 2017-09-22
Update (09/27/2017)
done...its faster than mac os journaled...via blackmagic disk speedtest
when on HFS Mac Os Journaled
on APFS
again this secondary harddrive im using SSHD Seagate firecuda..there's no Mac Osx/OS/Operating system even applicatons..is just a back up for non-system files like documents,pictures,videos,audio files and application installers that still in zip files or dmg...
im not rebooting my macbook from this secondary drive...my main drive is my 2TB SSD...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
I have the same set up on my MBP Early 2012. I chose Mac OS Extended (Journaled) and I use it for installing some large applications.
さんによる
Keep in mind some MacBook Pro's have issues with the optical bay SATA port. This is not the drive carriers fault, but an issue within Apples logic board.
I strongly recommend you review OWC Data Doubler to make sure your system does not have a problem. Also the 2.5" FireCuda drive is a fixed SATA III (6.0 Gb/s) drive unlike the older model which was an auto SATA sense drive which allowed it to work in older SATA II (3.0 Gb/s) systems.
Sorry to say the odd behavior of the MacBook Pro's which have this problem confuses auto SATA sense drives, you'll need a fixed SATA II drive instead (HDD or SSD).
さんによる
コメントを追加
1 件の回答
Presently you have no choice! Using the current gold release of High Sierra only allows you to convert SSD's.
I've been testing it across a SATA & PCIe SSD's. It appears the queue is shorter within a SATA connected SSD Vs a PCIe. I'm still working off of the last Beta and this week I'll be upgrading to the gold release.
It appears GUID/Mac OS Extended (Journaled) is the better for SATA SSD's. Until I test things under the Gold release I won't state that as fact yet!
The symptom I encounter is file write delays. You copy a snippet, URL, file from an App or one drive to another and it won't show up as fast as you would expect it could take a good minute to appear!
People who have Fusion Drive setups (have both a SSD and HDD drives installed) also can't use APFS either. Apple has stated there is more work going on on APFS which might explain things. Apple stated Fusion Drives will be supported in a future release.
Update (09/28/2017)
Yes, APFS is faster in reading & writing files over GUID/Mac OS Extended! The only problem I had with it was creating a file for some reason doesn't respond in a timely fashion.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
khaidir77 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 2,289
