iPhone 6 screen dim and dark
My Iphone has a dark screen. I have tried to adjust the brightness, but it is stil the same.
Is is the Ambient light sensor defect or is it a defect LCD cable? I have also followed a guide of how to fic dim screen without open the Iphone, but it did not work. So it has to be a defect part, but I dont know which part.
この質問は役に立ちましたか?
7 件のコメント
Can you explain a little more about your issue? When was it working last? What happened when it stopped working properly? Does Itunes recognize it? Can you still use it and it's just a dim screen with some backlight or do you need to put a flashlight to it to see the screen? Just a bit more history to make a proper suggestion on what you may be facing.
The Microsoldering Shop さんによる
I bought it used. I dont know the history of the phone.
But everything works perfect, ecxept from the brightness.
Anton さんによる
Do you see the screen even though dim without having to flash a light on it?
Yes, the brightness is at its lowest.
Anton さんによる
Mine very low it can't adjust I used touch to see it
Nui さんによる
2件以上のコメントを表示
