メインコンテンツにスキップ
Lenovo社によって製造されたラップトップモデルの修理ならびにサポートガイド。
2562回答 すべてを表示
3.5mm jack broke off and is now stuck
I (stupidly) used a cheap 3.5mm extension cable and the jack broke off inside my Lenovo Y50-70. Does anyone have an idea how to get it out? Or would I have to replace the entire audio IO part?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
i tryed useing a nail and that not work i did not have super glue but i used glue and that dont work an now another one broke in my switch pls help me also tried the pen trick it dont work
さんによる
コメントを追加
3件の回答
ベストアンサー
You can try using a plastic soda straw which is sliced so it can conform to the smaller diameter of the jack socket. Place the straw around the broken plug and slowly press it between the jack and plug once you’ve bottomed out you should be able to pull the broken plug out just like a cookie cutter does.
Here’s a metal version which I find is quite useful! GripStick Headphone Plug Extraction Tool
GripStick Headphone Plug Extraction Toolの画像
製品
$19.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This has worked for me a couple times on phones - Grab the plastic tube inside a biro or pen (i have also used a q-tip with the cotton end cut off), melt the tip with a lighter for a quick couple seconds and when the melted plastic is still malleable, stick it in on top of the broken jack. hold it there for a few seconds to cool down and then yank it out, (hopefully) the tip will be stuck to the end!
I hope that works for you :) otherwise i'm sure you will get some helpful answers from the other folk around here
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i found a usable but risky strategy of prying it out although my jack looks like blender blades were used in it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luis さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 48
今までの合計 11,918
