メインコンテンツにスキップ
JBL Charge 3は2016年に発売されました。独特のデザインのスピーカーカバーとゴムのアクセントで認識できます。 完全防水設計、最大20時間の再生時間、Bluetooth接続対応です。
89回答 すべてを表示
Where to buy replacement speakers for JBL Charge 3?
Where can I buy replacement front speakers for the JBL Charge 3? I have been trying to research where to buy, and have been unable to find a place to get them. I think one of mine is blown.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
6 件のコメント
I want to know the same thing. Cheers, TQ
さんによる
Yeah mine got a hole in the left speaker but no where to find
Cheers,
HJ
さんによる
Looking too. The charge port completely fell off. I can no longer charge my JBL3 :(
さんによる
You can replace the charge port, get the part on Amazon as well as the battery. Speakers you can find on Ebay.
さんによる
Hello, you can easily get speakers for JBL Charge 3 on the following website.
Original spare parts : https://ecommerce.mysav.eu/en/jbl/147-sp...
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
最も参考になった回答
Mike, the charge port is readily available and an easy fix. Watch the youtube video on how to do it and get the replacement charge port here in the States.
Henkjan, I found some replacement speakers from China that were the right dimensions for the Charge 3. Had to knock off the little guide post off the JBL frame that went through the speaker frame, but that is no biggie. I also put some flat washers (two in each corner) between the speaker and the JBL frame. Still had enough compression on the seal to keep it water resistant. Good luck.
Cheers,
TQ
Update (07/30/2019)
Here are two of the ones I bought that will fit:
https://www.ebay.com/itm/162694336905
https://www.ebay.com/itm/254053310184
As mentioned, the little "posts" on the JBL frame must be removed, or a hole would have to be drilled in the speaker frames to accomodate the posts.
Cheers,
TQ
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Hi Trevor,
Can you post here the link of the site where you've found right dimensions speakers for the Charge 3?
Thank you
Max
さんによる
Please share the link! My Charge has been sat in pieces for over a year now and to find some speakers (finally) would be so much appreciated!
さんによる
Trevor, you're a king! Ordered mine just now, thank you so so much!
さんによる
Hi Trevor. How would you rate the sound quality of the speakers ordered from China, compared to the oem jbl speakers? Better/worse/same?
さんによる
コメントを追加
Hi,
try Simply Speakers, there can be some spare parts for JBL.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gabriel Tovar さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 17
今までの合計 7,403
